408 problems
Old Apr 14, 2008 | 01:42 PM
GhostZ28's Avatar
Unhappy 408 problems
I was going to wait until it was done to post about it but I`m running into problems again. I bought the 408 stroker from TSP and the old ls1 oil pan won`t work with the new crank. The rod bolts are hitting some. It needs about another 3/8ths of clearence. Is there some kind of spacer I can buy or am I going to have to go a buy a new pan?
Old Apr 15, 2008 | 08:51 AM
Marc 85Z28's Avatar
Are you sure the rods/rod bolt aren't hitting the windage tray? Usually you see interference with the windage tray, and not the pan (depending upon what you bought). Shim the windage tray for clearance, but make sure the oil pickup height is adjusted to compensate!
Old Apr 15, 2008 | 11:17 PM
mrr23's Avatar
it should be the windage tray. i shimmed mine down 1/8" and thought it was enough clearance. while running the rods still hit. i ended up just opening the windage tray up, where the rods were touching at.
here's a pic of the windage tray before i notched it.
Old Apr 18, 2008 | 08:50 PM
Mike94ZLT1's Avatar
There are 2 things you can do. First off, if you got ARP main studs they will come with shims that you put under the windage tray that drop the tray lower so the crank doesnt hit it. The problem you then have (at least I did in my C5) is the windage tray will actually hit the oil pan in some spots, and require a little clearancing. Here is where I had to grind my C5 pan down...
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
