2k-3k bog
Old Jun 23, 2004 | 05:37 PM
muraoka's Avatar
2k-3k bog
i have a 99ss. ever since i got it it's bogged or stumbled between 2k and 3k. it doesn't all ways happen and it happens at different throttle positions. anyone have any ideas?
thanks matt
Old Jun 23, 2004 | 05:49 PM
Gloveperson's Avatar
Check every filter there is. Also look at your plugs/wires.
Old Jun 24, 2004 | 12:02 AM
muraoka's Avatar
thanks i'm new to the ls1 and haven't payed much attention to the car since i got it. spend most my time with my 97, but i just broke a ring and have to race the ss for a while.
Old Jun 24, 2004 | 04:56 AM
AL SS590 M6's Avatar
Moderator
Could be carboned up. Is it using any oil?? Sucking oil into the intake??
Old Jun 27, 2004 | 09:15 PM
whoa guy's Avatar
my z used to do the exact same thing. never did it at wide open throttle. clean your mass air sensor w/a Q-tip, but be really careful. dont use any cleaning agents. I hope this solves your problem. its been known that using oil air filters like a k&n can "gunk" up the maf sensor which causes incorrect readings.
Old Jun 28, 2004 | 12:17 AM
H/C LS6Z's Avatar
I'd agree with the first guy check your plugs/wires my bro's car used to do the same thing before he changed the plugs/wires
Old Jun 28, 2004 | 12:26 AM
muraoka's Avatar
it doesn't use any oil. did find a bad plug wire. it seems when i race the car i always get a ses (rear 02s). thank you all for your suggestions. hope i can find this so far nothing seems to help.
thanks matt
Alibi
Aug 1, 2015 07:50 PM
Bz8
Jul 13, 2015 04:46 PM
XKnightRider
Jan 4, 2003 09:40 PM
aziroc
Dec 10, 2002 04:27 AM
transamtom
Sep 11, 2002 04:28 AM
