2002 Z28 Stats
Old Apr 21, 2003 | 12:14 PM
TEAMSOKY's Avatar
Question 2002 Z28 Stats
My name is Josh. I just got a 2002 Z28 and i was woundering what kind of numbers it puts out. It is a Totaly stock six speed. I was looking for: HP, Torque (Engine or Wheels), and the 1/4 mile. Thanks in advance
Josh
Old Apr 21, 2003 | 12:37 PM
Capn Pete's Avatar
Cool
Hey man...........congrats on the new Z, and welcome to the board.
Well, since you've got the 6-speed (often referred to as M6 or A4 for the auto), they take a little less engine power to turn, so your driveline losses are a bit less --- maybe 10-15% vs 15-20% for an auto. SO, while the factory rates the '98 - '02 F-bodies at 305-310 HP, we all know that most of them will usually put anywhere from ~290 to 320 HP at the wheels (depending on year and transmission) which means the motor actually puts out about ~350 HP, same as the Corvette LS1. Torque #'s are usually between 320 - 350 lb/ft I believe.
***Don't quote me though!!!***
As far as the 1/4 mile goes, as long as you know how to drive the 6-speed well, running bone-stock on street tires, you're looking at a 13.something and 100+ mph (~105 mph roughly). My car with the A4 and 2.73's only ran 14.008 @ 103 mph, but I think that's on the slow end of the scale.
Well, have fun with your new car! They truly are great cars IMO (in my opinion), and whatever you want / need to know about it, you can pretty much find out on here..............I think just about everything has been beat to death a few hundred times!!!
Old Apr 21, 2003 | 01:11 PM
guywidiroc's Avatar
I just ran a new best with an 02 z28, check the sig. These cars should be low 13s unless altitude or temp is against you.
Old Apr 21, 2003 | 03:55 PM
JaysZ's Avatar
Just got mine dyno'd (check the sig). Haven't made it to the track yet- I'd be happy with low to mid 13's. There are some other some other guys here with some great '02 numbers.
Old Apr 21, 2003 | 06:30 PM
psychocabbage's Avatar
bone stock info in my sig.. also the car has been on the dyno over 40 times..
Very consistant!
Old Apr 21, 2003 | 07:13 PM
TEAMSOKY's Avatar
Hey thanks alot guys those number are better then i thought they would be. Thanks again i had looked on the net but was just getting pissed off cause i couldn't find anything that stock.
What would be the first performance mods your would do to it and how much would they help.
Old Apr 21, 2003 | 09:26 PM
2002Z28SSConv's Avatar
In order of bang for buck:
1) Air lid (on top of air filter)
2) SFC (Sub Frame Connectors)
3) STB (Strut Tower Brace)
4) 35mm Front Sway Bar
5) Bilstein HD shocks and lowering springs of your choice.
My $.02
Old Apr 21, 2003 | 10:21 PM
demonspeed's Avatar
I'd throw in a shifter at the top of that list, along with a catback...
Old Apr 22, 2003 | 12:56 AM
guywidiroc's Avatar
the lid is a must either way
Old Apr 22, 2003 | 12:28 PM
W3dgy's Avatar
bone stock with a little over 1k on it my best of 3 runs was a 13.8 at 104. that was also my first time ever at the track. im looking forward to what i can do this summer with the mods and being able to drive it a little better.
Old Apr 22, 2003 | 01:16 PM
well, keep in mind what you want...
I want a semi plush ride and dont need more power till i get the power i have now to the ground.
So the extra noise from the lid, I can do without.
I have in my garage, a panhard rod, and some LCA's.. Again, great parts and I loved them in my other car, but I want to keep mine smooth for a bit longer.
So, the extra stiffness, I can do without..
I may just get another airbag.. they really help on the traction plus they dont have any noticeable annoyance from the ride.
For $35 each ( you usually have to get 2 at a time so sell one to your bud) not a bad investment on a good launch..
(it goes in your right rear spring)
When i do start to put on the mods, I would focus as above on the traction side of it.. I dont know about you all, but I can break them loose even with drag radials so I think thats where I need to focus on.
ANDYZ28
Dec 29, 2014 09:13 PM
brandboZ28
Jan 31, 2003 06:19 PM
Rich_z28
Aug 27, 2002 12:20 AM
ChrisFrez
Aug 12, 2002 11:50 AM
