2000
Old May 14, 2008 | 10:55 AM
dwint's Avatar
2000
i have a new crate motor. dyno was 405 horse 425 torque.i put 3:73 gears in a raptor tranny and a 2000 stall.i have a comp cam 268 and 29 inch tires and air shocks for clearance reasons.i am wondering why i cant break the tires loose from a stop,the only thing i can think of is the low stall.any ideas?
Old May 15, 2008 | 06:30 AM
AL SS590 M6's Avatar
Moderator
What were you thinking? With that motor you should have at least a 3200 and that's a bare minimum. It would be way happier with a 3800 or so.
What gears do you have with those 29s. Should be 4.10s if you want an kind of performance.
Old May 16, 2008 | 05:03 PM
Kraest's Avatar
Retired
268 adv? That's roughly a 218 @ .050", which is a small cam.
Anyway, I agree with Al. That stall is too small especially when running a big tire like that and not a ton of gear.
Old May 17, 2008 | 07:34 PM
Chrome383Z's Avatar
2000 stall? I hope you didn't pay big money for that, that's barely anymore then stock and it's probably a heavy 12" converter. Dump the stall and tires. You don't need 29" tires.
Get a 9.5" 4000rpm stall and 26" slicks/drag radials and run 11s.
Your combo is completely out of wack.
Z28ELECTRICIAN
Oct 19, 2015 06:36 AM
68camaroboltz
Oct 5, 2015 11:56 PM
pepon214tx
Sep 20, 2015 04:48 PM
scottcba1
Sep 8, 2015 09:52 AM
tomfric
Parts Wanted
Jul 30, 2015 03:01 PM
