160 degree thermostat
Old Mar 24, 2008 | 03:43 PM
MeanZ687's Avatar
When installing the 160 degreee thermostat do you need to do anything with the computer and is it a pretty simple job?
Old Mar 24, 2008 | 04:26 PM
Kraest's Avatar
Retired
Simple job, but won't do much in regulating temperature or increasing power. Getting your car programmed for the fans to come on earlier is much more beneficial.
Old Mar 24, 2008 | 04:46 PM
Me>you's Avatar
He does not lie...Have fans come on earlier, that's what helps anyway...
Old Mar 25, 2008 | 08:18 AM
teke184's Avatar
A 160 stat with stock fan settings won't do anyting for cooling in heavy traffic or at the track. It will basically heat up as it does stock.
HOWEVER, as long as the car is moving sufficiently to keep the air going over the radiator, the engine will operate at a cooler temp. This is a good thing.
Reprogramming the fans is good, but your other option is a fan switch.
G-BODYT56
Jan 14, 2022 11:14 PM
Jeff1904
Jun 5, 2016 05:00 PM
plattted
9
Sep 20, 2015 11:23 AM
damnyankee36
Sep 9, 2015 07:06 PM
13qtr
Jul 19, 2015 05:30 PM
