140mph limit???
Old Jun 15, 2005 | 03:26 PM
gary80vette's Avatar
140mph limit???
Hi
What I want to know is - with the mods in my sig and using 97 octane fuel here in the UK I thought I should be able to go way beyond 140mph. It appears that acceleration in 5th up to 120+ is impressive then I shift into 6th and crawl slowly to 140-145ish where the car seems to sit regardless of how deep I try to bury the pedal into the floor.
Is there a problem or is there some adjustment/tweak I can do to get up beyong 150/160?
Thanks for the input.
Old Jun 15, 2005 | 03:29 PM
Z28COnrad's Avatar
Re: 140mph limit???
I don't know about the manual's but I've had my auto up to 145 and it was still pullin.....I'm certain the manuals can do so as well, maybe you need a tune up?
Old Jun 15, 2005 | 03:30 PM
CamaroBoy96Z28's Avatar
Re: 140mph limit???
No problem at all. 5th gear is where you'll find your top speed....not 6th. You'll hit your 150-160 in 5th.
Old Jun 15, 2005 | 04:27 PM
00ls1's Avatar
Re: 140mph limit???
yeah 6th gear isnt for accleration but fuel economy..
Old Jun 15, 2005 | 04:31 PM
SSpdDmon's Avatar
Re: 140mph limit???
Yup...like they said, you need 5th. What RPM's are you shifting at? 4,000?? Because unless you have gears, you shouldn't be shifting out of 4th until ~130mph.
Old Jun 15, 2005 | 10:08 PM
Z_boy's Avatar
Re: 140mph limit???
Wow, those dont seem right. The stock gears dont really allow you to go very fast in 5th. In my LT1 i would normally shift at around 120 in 5th and my rpms were between 5000 to 5500 i think, it was going up so fast i wasn't really paying attention.
Old Jun 15, 2005 | 10:39 PM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
Re: 140mph limit???
stock automatic...
151 was my max... and still climbing fairly fast... that was a little bit of a downhill.... only time i ever topped out... was 145.... with the t-tops off... UP a long hill... and it was still climbing... just hardly at all
RUENUF
Mar 13, 2016 03:37 PM
Sep 11, 2015 09:44 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
