100k miles 98z28
Subscribe
Jul 28, 2008 | 12:56 AM
turn 100 recently, i want to change my oil pump. I got a ls2 timing chain, are there any other parts i need to complete this job
Reply
Jul 28, 2008 | 06:39 AM
WP gaskets, timing cover gaskets, and coolant. You will also need a puller/installer for the harmonic balancer/hub plus a new bolt (and yes the new bolt is necessary) with a HD angle torque wrench.
Reply
Jul 28, 2008 | 04:28 PM
Is there something wrong with it? It is really tricky getting the pickup tube lined up properly and stuff like that. I wouldn't mess with it unless you know you need it.
-Geoff
Reply
Jul 28, 2008 | 07:52 PM
i just installed a slp underdrive pulley, its about a month old, do i still need a new balancer bolt
Reply
Jul 29, 2008 | 06:54 AM
Quote: i just installed a slp underdrive pulley, its about a month old, do i still need a new balancer bolt
Yep, that bolt along with the head bolts are a one time use item.
Reply
Jul 29, 2008 | 09:52 AM
got part numbers for the gaskets and the bolt
Reply
Subscribe
