0w-30 Synthetic Oils
Old Aug 7, 2007 | 10:27 AM
NASCR46's Avatar
I currently use Mobil 1 5w-30.The engine is very noisy at start up.Would 0w-30 quiet things down?
Old Aug 7, 2007 | 12:01 PM
Greed4Speed's Avatar
I used oil when I ran Mobile 1 so I stopped running it. I'd try a different brand and see if that helps.
Old Aug 7, 2007 | 12:25 PM
Sparkz28ss's Avatar
no...but 20-50 would
Old Aug 7, 2007 | 12:40 PM
NASCR46's Avatar
Ok I'm confused .Wouldn't a heavier oil not flow as well at start up.The engine is only noisy at start up when cold (lifters,Tappets or Something) that's why I thought a 0 viscosity would flow better
Old Aug 7, 2007 | 04:28 PM
Have you ever ran a different oil or owned an LS1 before? This may be the normal start up noise. These engines aren't quiet and have bee known to have piston slap.
Old Aug 7, 2007 | 08:08 PM
Zitty'sZ's Avatar
Yes, you are correct that a heavier oil will not flow as well on startup or any other time. The clearances on these engines dictates the use of 30wt oil and I would not use 20w-50 . As suggested try another brand of oil and see what happens.
Old Aug 8, 2007 | 07:53 AM
teke184's Avatar
i remember on my 65K mile LT1....i tried some of that new Mobile1 "performance" 20w-?? that they came out with about 4yrs ago.
the engine made so much racket i was gonna drain it well before the 3000miles.
it was crazy how much noise the engine made...and that was switching form 10w.
Old Aug 13, 2007 | 03:56 PM
Syn's Avatar
Syn
i run 0w40 but seriously am about done with mobile 1, ams oil is going in next.
i've used royal purple and really liked it, but the 3 last oil changes have been mobile 1.
Old Aug 14, 2007 | 05:47 AM
AL SS590 M6's Avatar
Moderator
I'm not ever going to use Royal Purple again. I had my pan off this last winter and it was all coated with a purple/black residue. A few years before when I was running M1 it was as clean as could be inside.
Old Aug 14, 2007 | 10:33 AM
350 HRSS's Avatar
I am not going to get into a debate, but I will tell you to get that 0w oil out of your engine. I have used both AmsOil and Mobil 1 0-30, 5-30 and 10-30. I had lots of engine wear from any synthetic I used. MUCH more wear from the 0w oils. The so-called gains are really not worth the price you will pay in the long run.
I back this up from the oil samples I sent to:
http://www.blackstone-labs.com/index.html
Which noted in EACH oil sample from my 95 LT1 and 99 LS1 the synthetics were causing engine wear incredibly fast. I switched over to a recommended Havoline 10-30 (just regular oil) and my engine wear went down considerably with each oil change of 3,000 miles.
I will never use overly-priced synthetics again.
Old Aug 14, 2007 | 04:08 PM
SteveC's Avatar
From: Poway CA, where GOD and the sun always shines
Thumbs up
I fully agree, 0W-30 should ONLY be used in the coldest of climates, I would run a 10W-30 in summer and switch for winter.
I live in a very warm cliamate, and use 10W-30 year round.
SteveC
Old Aug 14, 2007 | 04:16 PM
JakeRobb's Avatar
Super Moderator
If these things happen in anything other than sub-freezing weather, it doesn't matter what the first number is.
Old Aug 18, 2007 | 03:44 AM
med_reject's Avatar
most synthetics are grade III (since U.S. courts legalized the marketing of dino oil as synthetic if it has certain properties), and do not offer the same level of protection as a true synthetic.
Try an engine analysis with german made castrol 0w30 synthetic. According to Bob is the Oil guy, that yielded almost zero wear, and much better results than Mobil 5w30 "synthetic" - that was in an LT1, but the results should be similar in other cars.
Its also the only oil available in north america that BMW has approved for their "long life" standard. BMW recommends oil change interval to the tune of every 20k miles
RX Speed Works
Jul 24, 2015 02:25 PM
big_mac421
Jul 13, 2015 03:48 PM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
