'01 manifolds and cats on a '98 Z28
Old Apr 14, 2006 | 11:42 PM
chuck's Avatar
I understand the '01 manifolds and cats flow much better than the '98's. I have a low mile set of '01's in the garage, and was wondering what kind of gain could be expected from this swap?
Old Apr 15, 2006 | 12:03 AM
teke184's Avatar
Re: '01 manifolds and cats on a '98 Z28
if you're lucky.....5hp
cats are the same...manifolds are slightly better.
not worth the effort
Old Apr 15, 2006 | 12:31 PM
V6toZ28's Avatar
No EGR hook up on the '01s ...
Old Apr 15, 2006 | 12:47 PM
Greed4Speed's Avatar
You live in TX, put some headers on it!
Old Apr 15, 2006 | 12:49 PM
Domster_ss's Avatar
You should a LS-2 intake on it. They flow almost as much as a fast but for alot less. But answering your question. Yes they will both bolt up.
Old Apr 16, 2006 | 01:28 PM
V6toZ28's Avatar
Originally Posted by Domster_ss
...Yes they will both bolt up.
That's assumiing he is also using the '01 y-pipe ... a '98 y-pipe will not bolt-up to '01 cats and manifolds.
Old Apr 16, 2006 | 07:45 PM
Sure if you want to lose intake charge velocity. On a stock cubed LS1: LS6 intake > LS2 intake.
Plus you won't have the hassle of the TB....
Old Apr 18, 2006 | 07:54 AM
AL SS590 M6's Avatar
Moderator
If you have way more time that funds, why not. But if money is a real problem then be aware that the 01 manifolds have no provisions for EGR so you'd have to eliminate that, which will set a code that you'll either have to live with a perpetual SES or pay to have it turned off. And the A.I.R. flanges are turned 90° from one to the other so you'll have to try to twist you pipes or buy the 01 pipes.
I have the manifolds off a 99 here and the manifolds off my 00 and there's a huge difference in the size of the ports and internal passages. Our stock 98 M6 car has run a best mph of 107. And my 00 A4 car ran 108.
Old Dec 8, 2007 | 07:34 PM
sn8ke eatr's Avatar
ls2 intakes are made like garbage. as said above, get an ls6 intake with some nice headers and itll really wake up
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
spearous
Jan 12, 2015 11:03 AM
Jan 5, 2015 07:14 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
Jul 4, 2005 05:00 PM
