Z28 questions before I buy
Old Aug 16, 2005 | 04:25 PM
speed211@bigstring.c's Avatar
Whats up all!
This is my first thread on this forum.
I am looking at a 96 Z28. I am not knowledgeable on newer camaros so I have a few questions. First Is there anything about 96 camaros that would make them more or less desireable than other years?
Also the car has been worked over....It has a lopey cam. and the owner is claiming that the bottom end has been converted the a 383 stroker...can you do that with the LT1?
My last question is the tranny is an automatic and has the B&M shift kit installed......It really makes the car vibrate especially in 3rd gear...is that normal or should I be looking for tranny problems?
I appreciate any feedback....I don't want to buy a lemon!
Old Aug 16, 2005 | 04:53 PM
2000GTP's Avatar
Re: Z28 questions before I buy
When you say you are knowledgable about newer camaros, I am assuming you are speaking of the LS1s which from the factory are faster than the LT1s in the 93-97s. As for the body though, they are essentially the same. It is possible to do a 383 stroker out of an LT1 block with the help of a die grinder in some spots.
As for the vibration in 3rd gear, it may not necessarily be the trans., but maybe the driveshaft or some other ailment.
Finally, as for buying a lemon, please realize you are buying a cammed, stroker car so whenever you start modifications, reliability is sacrificed. Look the car over well before buying and good luck.
Old Aug 17, 2005 | 08:31 AM
Kataklysm's Avatar
Honestly I wouldn't buy a car that has been modified that much, it was probably beaten on and will give you problems. The transmission shakes? Is this 6 speed car? I know you said shift kit but maybe the seller doesn't know what he's talking about and thinks you can put a shift kit in a 6 speed.
Old Aug 17, 2005 | 04:32 PM
Z28Performance's Avatar
read the post again... he said he is not knowledgable of the new camaros.... he must be familar with the 60's - 80's
Old Aug 17, 2005 | 06:38 PM
2000GTP's Avatar
Thanks for the clarification.
Old Aug 17, 2005 | 06:52 PM
Chris 96 WS6's Avatar
As an LT1 owner, my best advice is hold out and buy a stock LS1 car....much better basis upon which to build a car.
cmdeshon
Dec 27, 2014 10:06 AM
Queens94z28
Dec 20, 2014 09:11 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
heavenly_six
Dec 10, 2014 12:23 AM
