Z28 lt1 5.7 1995 camaro has spark and fuel wont star for more then 5 min
Hi guys my name is Mike
I have a z28 camaro 1995 lt1 5.7 has 178 k miles on a summer night i was leaving my friends house after letting the car warm up for 5 mins got about a block down the street the car made a pop sound and stops i push it back to my friends and stayed the night the next morning i get in and it starts i make it home (10 miles) where I started trouble shooting i changed the fuel pump in-line filter went to start it runs good for 5 mins then cuts cranks but won't start until some time changed the coil pack and icm got a mechanic to come check it out and wasn't getting spark changed the opti (duralast ) and water pump didn't change took it apart again and checked the rotor screws they were good changed spark plugs sprayed starter fluid too still wouldn't start or stay running when changed the spark plugs they were more dry then should be also attempted to give gas while starting it even though it has fuel injectors would bog like it wanted to start still wouldn't the cool air duct that connects to the throttle body had some dry rought changed it I changed the fuel pump relay still hasn't changed
someone please help its been like this for 5 months
Im 22 I love the car show me the way
thank you
thank you
Re: Z28 lt1 5.7 1995 camaro has spark and fuel wont star for more then 5 min
Have you scanned it for codes? Not all codes turn on the SES light.
Have you checked the fuel pressure:
- after the pump primes, and shuts off, without starting the engine
- at idle, with vacuum compensation line on the fuel pressure regulator?
- at idle, with vacuum line off the FPR?
- on the road with engine under max load?
What brand is the new fuel pump? There are a lot of low quality Chinese counterfeits on the market?
When it runs for 5 minutes and the engine shuts off, is that sitting at idle, on the road being driven, or both?
Scanned it for codes nothing pops up i can't remember the brand name for the fuel pump but im getting 45 pressure and i haven't been driving while its happened but when it starts to die I'll give it gas to try keeping it alive and it'll still fall out where I screw in to get the pressure is after the fuel regulator so im guessing its not that
The Schrader valve (pressure test) is in the fuel supply line, not after the regulator. The regulator controls pressure by controlling how much fuel is returned to the tank. It is possible for the fuel pump to heat soak. Did you check the fuel pressure immediately after it shut down? When you replaced the pump did you reuse the factory "bucket"?
What did you use to check for codes?
I used an old scanner i have 45 pressure when I turn the key and when it runs it even goes up a little I recently scanned it after putting in the opti
When the engine is running at idle, and the vacuum compensation line is attached to the fuel pressure regulator, the pressure should be about ~35 PSI with a stock cam. With the vacuum line off the FPR, pressure should be 43.5 PSI. GM spec accepts anything in the range of 41-47 PSI. If the pressure does not drop whe the vacuum line is reattached, something is wrong.
http://shbox.com/1/fp_reg.jpg
When you scanned you car did you happen to check all of you cars parameters? I have seen this before ambient temp will be like 70 degrees and the coolant temp will show 30 degrees so it trying too do a cold start and will over fuel it and not start soon I would check Temps out and the 5.7 has two coolant sensors on for gauge and one for ecu
ronniejr38
Sep 19, 2006 06:26 PM
