Z28 Convertible Rear Window??
I recently purchased a 2002 Z28 convertible and noted that the top of the rear window is not properly secured to the convertible top. I wonder if someone can tell me how the top of the rear window is supposed to be attached to the top. Thank you.
Re: Z28 Convertible Rear Window??
The window is glued in. I did a "search" and found this thread that mentions an adhesive specifically for this purpose.
https://www.camaroz28.com/forums/gen...window-526525/
I'm not sure what causes this, I've wondered if driving with the windows down at highway speeds plays a part in this. With the windows down, the top becomes inflated and puts an outward pressure against the rear glass. Over time, I suppose this could be the cause. This condition also puts pressure on the top's attachment to the last top bow before the window. If this attachment point detaches from the top, the fabric of the top will no longer cover the top edge of the rear glass. If your old enough to remember, the convertibles of the 50's and 60's had a zippered rear window, so this wasn't a problem.
