yet another VATS thread
Old Apr 26, 2006 | 09:24 AM
  #16
30th TA 0219's Avatar
Re: yet another VATS thread
Originally Posted by smoknta
I'm not sure if the vats disables the fuel pump or the injector pulses. But yes the vats disables the ignition as well. There is a relay behind the glove box.
can you simply bypass it?
Right now, I can turn the key on, jump from the battery to the solenoid wire, and it fires right up and runs. The security light flashes but who cares. I was just going to rig a push button starter if the VATS/PASSkey cannot be easily (CHEAPLY) bypassed.
NEED HELP TODAY!!
Old Apr 26, 2006 | 10:38 AM
  #17
khojo16's Avatar
the VATS system disables the fuel pump and the starter...i had to go thru all the b.s. when i was tryin to figure out wut to do to fix my car...ended up with a new bcm
Old Apr 26, 2006 | 05:53 PM
  #18
well, technically, this is PASSkey, and NO it doesn't disable the FP, as stated my fuel pump and injectors work fine, th ignition is dead. I'm in the process of wiring a Moroso remote starter button
Old Apr 26, 2006 | 09:29 PM
  #19
You just have to bypass the theft deterrent relay if it will run like you said. Schematics are on my site.
Jeff1904
Jun 5, 2016 05:00 PM
n2oblkz
Oct 22, 2015 02:31 PM
colts0455
Oct 4, 2015 09:47 PM
colts0455
Sep 27, 2015 01:07 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
