WOW borla is screwing me over.
Old Nov 2, 2005 | 09:13 AM
  #16
95LT1Z28's Avatar
Re: WOW borla is screwing me over.
If you bought the Hooker long tubes and their ORY you do not need the "s-pipe". The intermediate pipe (long pipe that goes from middle of car just to the over the axle tube) is the one you want to mate up with the hooker y-pipe. The S-pipe is only needed if you already have a '96-'97 cat-back exhaust and want to convert it to a single cat header and y-pipe setup. So all you should have to do is the remove the S-pipe on your car now and everything should "bolt" up. Unless I am misunderstanding something this should work for you.
Jeff
Old Nov 2, 2005 | 11:51 AM
  #17
matrik's Avatar
If I remove the S-pipe on my car, i'm missing a 2 foot section of pipe. I'm trying to converter a 95< cat back to 96/97 dual cat y-pipe. So i need a s-pipe to go from the 95 catback, to my newer headers.
Old Nov 2, 2005 | 03:44 PM
  #18
95LT1Z28's Avatar
Does your new y-pipe connect to the cat-back in the middle of car or off to the side where a catalytic converter would be on a single cat car?
Old Nov 2, 2005 | 06:06 PM
  #19
matrik's Avatar
Its much more in the middle than my single cat y-pipe was. Its definetly not on the far right like on the single cat y.
Old Nov 2, 2005 | 06:46 PM
  #20
95LT1Z28's Avatar
Since it is in the middle you should not need the s-pipe. I should probably scrounge up a pic and see if that helps you out.
Old Nov 2, 2005 | 07:04 PM
  #21
DiabloGT's Avatar
i can sell you my s pipe for $20, i didnt even use it cause of lts
Old Nov 3, 2005 | 04:14 AM
  #22
matrik's Avatar
Pmed you, tryin to make sure its the right thing.
PopoFormula
Oct 12, 2015 04:19 PM
WobblySausage
Oct 7, 2015 02:44 PM
autoxr166
Sep 25, 2015 04:21 PM
Z Power
Sep 19, 2015 11:19 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
