wont start or turn over
Old Dec 18, 2011 | 02:47 PM
Robs94camaro's Avatar
Just got my 94 3.4 v6 camaro on friday drove it all day and went out that night.. Went to warm it up for work next morning and everything lite up like its normally would but nothing happend.. I checked and charged the batt, check and replaced the starter, still nothing.. I hear a click sound over by the glove box when i turn the key.. need help on what to do.
Old Dec 20, 2011 | 12:28 PM
IRONFIST's Avatar
Re: wont start or turn over
If you hear a "click" that means you're either not getting enough power to the starter or the starter is shot.
Although the click shouldn't be coming from the glovebox, it should come from the starter.
Old Dec 20, 2011 | 04:20 PM
It's a little confusing, because he has two threads going on the same topic.
https://www.camaroz28.com/forums/fue...d-help-844446/
The theft deterrent relay is part of the circuit, and that's on the right-hand side of the dash, so that may be the noise he is hearing.
From Shoebox (94 is similar):
http://shbox.com/1/starter_charging_95.jpg
Old Dec 20, 2011 | 09:05 PM
sorry about the mix up im just geting use to the site... The click was the theft deterrent relay and the problem was the small wire on the starter going to the relay.. the soldaring (i think i spelled that right) had completely came off therefor causing it to short.. it ended up being a semple fix after testing and retesting..
meissen
Jun 1, 2015 07:59 AM
eazyZ
Mar 1, 2015 07:12 AM
camy 1993
Feb 3, 2015 06:26 PM
A's 91 Z28
Dec 7, 2014 12:09 PM
formula79
26
Aug 5, 2002 12:21 PM
