Which wire?? Need Help
Where at the PCM do I hook the wire from my autometer lunar series air/fuel ratio gauge wire? It says connect to the purple wire on the pcm, but there are 4 of them! Any help would be appreciated!
-Travis
-Travis
Re: Which wire?? Need Help
You have to select whether you want to hook it up to the left (pin C20, purple/white) or right O2 (pin C8, purple) sensor. Or run both wires to a single pole/double throw switch so you can select either.
surreybrad
Apr 22, 2015 06:40 AM
Brandon Wittmer
Dec 3, 2014 09:28 PM
