wipers
Old Sep 18, 2004 | 10:24 AM
Ramza's Avatar
wipers
interesting windshield wiper problem. They work fine and all, except for the fact that when i shut them off, they stay in the up position. if i manually put them down they go right back up. im a little confused on this one.
any ideas????
Old Sep 18, 2004 | 11:22 AM
kingman109's Avatar
Re: wipers
hmm i have same prob - i just figured i didnt seat something right when i rebuilt my whole front end and replaced them -
Old Jan 30, 2006 | 01:41 PM
Transamdriver's Avatar
Re: wipers
Im going to bring this back to the top because mine started doing this today. When I turn them off they go up and stop in the up position, almost like the circuit reversed itself.
Searched some more and it appears I will just have to replace the motor.
Old Jan 31, 2006 | 10:59 PM
IROCET's Avatar
Re: wipers
Mine did the exact same thing about 3 months ago. Sounds like it is time to replace the motor. It is not a difficult job at all, but a couple bits of advice for you. First, get a battery terminal puller (got one at NAPA for $20 or so) to get the wiper arms off. It makes it very easy to get them off and will prevent you from cracking the windshield. Second, the arms that connect to the motor and to the drivers side wiper gear should just pop off by using a big screwdriver. When you put them back together, make sure they pop twice (I used a pair of vice grips to do this). It will take quite a bit of pressure, but will save you from having to tear the whole thing apart again. Good luck.
Matt
Old Jan 31, 2006 | 11:38 PM
Z95m6's Avatar
Re: wipers
Matt
Matt has some very good advice on this. I believe when your wipers wont go back down because the circuit board in the motor is bad. I've heard you can just swap the boards but its easier to just swap motors. If you ask me messing with the wipers is a total PITA. You have to make sure the little rubber mounts for the motor get firmly into place or the motor will rock back and forth at high speeds and cause your wipers to hit the cowl.
Old Feb 2, 2006 | 04:32 PM
camaro777tom's Avatar
Re: wipers
I have the same thing happening. I got a new motor controller (I think this is the problem) but never put it on. Pulling the wiper arms just seems like a real pain in the *ss.
Red Hawk 94
Mar 18, 2019 04:03 PM
autoxr166
Sep 25, 2015 04:21 PM
stopthatman
Feb 9, 2015 09:00 PM
Kris93/95Z28
Feb 27, 2003 01:04 PM
Mr Freeze
Feb 11, 2003 08:19 AM
