Windows?
Old May 14, 2004 | 01:52 PM
Z28WannaB's Avatar
Windows?
my 95' formula firebird's passanger window gets stuck.
What is more likely the problem?
How do I get the interior on the door off?
Old May 14, 2004 | 02:47 PM
99blackSS's Avatar
Next time it stops on the way up leave it as far as it is, then wait five minutes and try to roll it up more. If after the five minutes it lets you roll it up more it is probably the motor.
If it remains stuck then it is either your regulator or your tracks just need greasing. I haven't replaced a camaro regulator before but I know greasing the tracks would be easier so try that first.
click here
The first few steps show you how to access the inside of the door.
Old May 26, 2004 | 06:40 PM
Z28WannaB's Avatar
The regulator are those brass things with the soft black stuff at the end that keeps the window from falling on you correct?
Well those seem to be worn, however it doesn't look like they are preventing the window from going up.
Sometimes the motor makes a sound like its trying to go up and sometimes it doesn't. The window always gets stuck at the same spot too. I've tried pulling it up manually, however it seems stuck in that one spot.
So should I try and grease the tracks or go buy a new motor?
- Z28WannaB
Old May 26, 2004 | 08:40 PM
99blackSS's Avatar
It'd be a lot cheaper to try greasing the tracks first.
THe regulator is a scissor looking peice. Pic of a camaro window regulator. That one also has the motor attached to it.
OutlawPerforman
Oct 30, 2017 05:40 PM
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
z28cam1993
Sep 9, 2015 04:08 AM
Jul 10, 2015 02:23 PM
