Window wont move
Old May 14, 2006 | 06:52 PM
Beyonce Knowles's Avatar
Window wont move
Out of nowhere my driver's side window stopped moving. It is all the way down and when I try to roll it up nothing happens. I've had the motor die out over time as they tend to do, but this time out of nowhere it just went out. There is zero sound or any indication that the motor is doing anything when I pull the switch up. Not sure if it is a coincidence, but the power side view mirror switch isnt doing anything either when I try and adjust my mirrors. Any idea of where to start other than replace the motor?
Old May 14, 2006 | 07:02 PM
stingercamaro's Avatar
Re: Window wont move
I had this happen one time. I don't know what it's called but there is a small wheel that attaches to the window and slides down the "X" frame. It broke while the window was down and the window came off the track. As soon as I reattached it, the motor started working just fine.
Is the window kinda flimsy?
Old May 14, 2006 | 10:43 PM
I'd look at fuses before anything else...
Old Jun 9, 2006 | 03:16 PM
MacPHYST's Avatar
The same thing just heppend to me. Yesterday I had my window down and it wouldn't go up while pressing my switch. Tried it again a little later that day and it worked like normal. This morning it rolled down but by the time I got to work to roll it back up...nothing...not even a sound. Went to get my car inspected today during lunch and bought a new driver's side switch while I was there. Put it in and nothing still. Passenger side window works fine from the driver's switch and I didn't try the side mirror adjustments. I'll look at my fuses this evening.
Old Jun 17, 2006 | 01:10 AM
Skywise's Avatar
How'd this turn out? I'm having a similar problem with my 97 Camaro. No response from either the passenger or drivers side switches then... suddenly everything's working fine. Fuses look ok.
Old Jun 17, 2006 | 10:02 AM
MacPHYST's Avatar
My problem turned out to be that my motor aparently got wet during a heavy downpour of rain. It worked sort of "on and off" one day and then just stopped working. After realizing that the new switch I bought didn't work, I pulled the motor out of my door and as I was holding it in my hand, water poured out of it. Unfortunately, I had already replaced one under a lifetime warranty and the folks at the parts store told me that since this was a second replacement under a lifetime warrantie that this part only has a warranty of 90 days. That being said, I had to buy a new one for $50. So basically, the next time this happens, I can get a free replacement. Then if it happens again after 90 days, I'll have to buy a new one.
Old Jun 17, 2006 | 07:22 PM
ochinkruta's Avatar
How ironic is this... I was just in the garage trying fix mine too! Worked perfectly this morning, then when I got to work it wouldn't move. I can hear the relays click though. I just pulled the panel off, and it started working again . The only thing I have noticed is that one of rivets on the regulator broke.
Old Jul 4, 2006 | 02:01 PM
Bow94z's Avatar
yea i just had the same problem the other night, and it just got done raining hard for the past couple days...
it still works here and there
time for a new motor then?
Nayr
Mar 3, 2023 08:34 PM
LT14LIFE
Nov 15, 2015 06:22 PM
mmf_1013
Sep 12, 2015 08:56 PM
jackpawt883
Sep 10, 2015 08:53 PM
z28cam1993
Sep 9, 2015 04:08 AM
