Window switch
Old Aug 30, 2008 | 10:04 PM
The Captain's Avatar
Window switch
My drivers side window switch crapped out on me, and now my window wont go up. Its only cracked about an inch, but I would like to get it all the way up in case it rains before I can get a new one. Does anyone know which plugs I need to jumper together to make it go up? I found this on shbox's site, but really cant figure it out.
http://shbox.com/1/pwr_window_schematic.jpg
Also, are all the switches interchangeable between 93-02? I know my 93 is yellow, and I dont care if it doesnt match.
Old Aug 30, 2008 | 11:38 PM
There are only two wires that end up going to the motor. Put power and ground to the dark blue and brown on the motor leads. Reverse polarity to reverse the motor. Or if you are doing it at the switch connector, try the dark blue and the gray (which goes through the express down module).
http://shbox.com/1/window_motor_switches.jpg
Old Aug 31, 2008 | 11:09 AM
which ones are power and ground?
Old Aug 31, 2008 | 01:05 PM
At the switch connector and according to the schematic, black is ground and brown is power. But if you are having trouble getting either to that point, you might want to jump it from another location.
Old Aug 31, 2008 | 01:57 PM
Thanks for the help
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
z28cam1993
Sep 9, 2015 04:08 AM
