Window Regulator Spring Broke !
Old Mar 22, 2007 | 12:39 AM
Spllouder's Avatar
well i noticed that when i shut my drivers door some time i here like a bang some times , So I pulled of the door panel , and inside the door laying in the bottom of the door was the broken circulir spring ? are these big springs even known for braking . how do i go about replacing it . whats it there for ?
also on a off-topuc question whats the part numer for the outher wheater stripping for the window . ( You know at the top of the door and bottom of the window on the outside of the car . Thanks
Old Mar 22, 2007 | 10:58 AM
Z28SORR's Avatar
The window regulator spring assist the motor in closing the heavy window.
I have not heard of a generic problem with these springs.
You need to look closely at the window reg. mechanism and see if some other failed part caused the spring to come off or brake.
I know you can buy the "regulator assembly". But not if you can get the spring alone, dought it.
I would replace the entire assembly, that way I know I have any hidden problem taken care of.
Old Mar 22, 2007 | 05:57 PM
Spllouder's Avatar
how hard would it be to repace the whole regulator ? about how much do they cost ?
Old Mar 26, 2007 | 01:00 PM
Z28SORR's Avatar
I "think" it was around $125.00 for the reg. and motor assem. It's not much worse then just the motor. For me it's the same, as I always remove the reg. when I do the motor anyway.
Keenan
Jan 19, 2023 12:24 PM
Speeds8erM-1
Aug 20, 2002 09:12 PM
Speeds8erM-1
Aug 15, 2002 10:07 PM
Speeds8erM-1
Aug 13, 2002 10:24 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
