Window problem
Old Mar 6, 2009 | 09:26 PM
moparman's Avatar
Window problem
No, not the motor. The driver's side window is acting funny. When it's rolled down, it sounds as if it is binding towards the rear of the door. Something also seems to cause the door panel to bulge out slightly. When it is rolled back up, sometimes, it doesn't go into the track at the front of the window, by the mirror. I have to give it a nudge to get it into the channel. I took the door panel off and looked inside the door, but didn't see anything that looked suspicious, but that could be due to not knowing what to look for. Car is a '96 Formula, power windows.
Old Mar 7, 2009 | 09:08 PM
moparman's Avatar
ttp
Old Mar 7, 2009 | 10:02 PM
madhatter's Avatar
Get a new regulator.
Old Mar 7, 2009 | 11:32 PM
Spartan7's Avatar
I'd say part of the window channel is broken. Same thing was wrong with mine, and one of the rollers broke off the channel.
Old Mar 8, 2009 | 01:24 AM
mrmint69's Avatar
I use white lithium grease to lube the channel and other components of the regulator. It will help make the glass move up and down smoothly.
Keenan
Jan 19, 2023 12:24 PM
NewsBot
Apr 11, 2015 11:44 AM
guruerror
Mar 4, 2015 06:25 PM
warmeck
Feb 2, 2015 12:44 AM
The Seer
Nov 20, 2014 06:32 AM
