Window Motor - Weird Problem......
Old Aug 7, 2006 | 03:32 PM
csbarnes1's Avatar
(I couldn't find any old threads about this) I have a '95 Z and the driverside power window works, but the window does not roll up or down. You can hear the motor turning when the button is pushed. I pulled the door panel off and found metal shavings. What piece or pieces would you recommend checking? Is there a gear or something that may have worn? Thanks for the help!
Old Aug 7, 2006 | 05:00 PM
Bryan 94 Z28's Avatar
Re: Window Motor - Weird Problem......
You may have sheared off the teeth from the gear that the motor actually turns to raise and lower the window.
Old Aug 8, 2006 | 01:43 PM
RE AND CHERYL's Avatar
Probably bad windor regulator.
Keenan
Jan 19, 2023 12:24 PM
capebuf
Jan 13, 2015 07:22 PM
97z28k&N
Jan 9, 2015 04:58 AM
Jazsun
Dec 29, 2014 12:14 PM
