Window goes half up..then stops...then goes again
Old Jun 3, 2007 | 02:39 PM
O6NinjaZX6Rider's Avatar
93 Z28.
Window goes up like 1/4 of the way...stops...i wait like a minute then it goes up a little more...then i stop wait and then it goes all the way up in a minute of two..
Regulator??
Old Jun 3, 2007 | 02:41 PM
2000GTP's Avatar
Originally Posted by O6NinjaZX6Rider
93 Z28.
Regulator??
Sounds like the symptoms of a dying window motor. Check out Shoebox's website as it has a great tutorial for this as well as many other things. You can pick up these motors from most parts stores for around 50 bucks and they usually include a lifetime warranty. http://shbox.com/page/windowmotor.html
Old Jun 3, 2007 | 02:44 PM
TBI_InYourEye's Avatar
Yep. Your window motor is breathing it's final breaths. Follow the instructions on the shoebox site listed above, it's really pretty easy. I've had to replace a window motor or 2 on every f-body I've owned. They're garbage.
Old Jun 3, 2007 | 02:47 PM
BlackDog's Avatar
Check this out, AutoTrix F-Body passenger window fix kit
http://www.autotrix.net/index.html
Old Jun 3, 2007 | 02:50 PM
JakeRobb's Avatar
Super Moderator
As a temporary fix, you can bypass the thermal regulator. You should still plan on replacing the motor with a new one.
Old Jun 3, 2007 | 03:02 PM
alrighty then thats what im doin on tuesday
thanks guys
blazzen's Avatar
my window did the same thing. I ran a power wire straight from the battery into two relays. wiered them int to the switch, and it goes up faster then it did then when the car was new.
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
alliance12364
Sep 23, 2015 12:40 PM
damnyankee36
Sep 9, 2015 07:06 PM
z28cam1993
Sep 9, 2015 04:08 AM
