Will a Coolant Flush Get Rid of the Low Coolant Light?
My low coolant light comes on after about an hour of running, the coolant is not low but its the case of the dirty coolant sensor.
Will a coolant flush fix the problem, or does the coolant sensor need to be replaced?
I doubt just a coolant flush will clean the sensor enough. I'm on my third sensor. Once the light comes on, I have just replaced the sensor. Some have tried cleaning the old sensor will some sucess though.
I've had this happen on both my 87 Vette and my 97 Camaro. After cleaning and flushing the coolant system, the sensor has gone back to normal,(started working, light off). Unfortunately it only lasted a few months and the light came back on again.
Bahh Unplug the sensor. It doesn't do anything but drive the light. Just check the coolant level every once in while.
I unplugged my sensor about two years ago after my light stayed on even though I had full coolant levels. No issues whatsoever.
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Sandersen511
Jan 13, 2015 03:49 PM
