why does our stock fog light crack or break?
Re: why does our stock fog light crack or break?
Replace them with Hella FF75s, they are a huge improvement in brightness.
Ok so now I have some hella FF75 fog lights, how did you mount yours.I searched and seen that you(BUD M) made some brackets that were triangler in shape .I need some pics or a drawing.can you help me out?
The ones on my 93Z were bought from Autozone come with 55 watt bulbs, I upgraded to 100 watt bulbs once they started to burn out. They fit right in the same location and look almost stock.
I need to replace mine. Can I get some pics of how they mounted? Or is there a certain mounting bracket that I need to look for when I purchase them? DId you just wire into the stock harness?
It depends on what wattage bulbs you run. On my fogs i'm running 55 watt bulbs so i'm running the stock harness. On my headlights i'm running 100 watt bulbs so i put in supplied Hella harness. Also for people with the Hella Foglights you might want to spend the extra money on getting the clear plastic lense protectors. They snap right on and will save you from buying new lights if your lense cracks.
Running lights for headlights and foglights for the fogs. The fogs have a very wide horizontal pattern but don't go out very far, the driving lights are like little spot lights. They have a very tight light pattern.
Fog lights are for fog. Driving lights are what you want.
Brake_L8
Jan 20, 2015 09:44 AM
30thZ286speed
Aug 3, 2002 04:54 AM
