Where is the remote gas tank vent located?
Old Nov 28, 2007 | 02:37 PM
mrmint69's Avatar
I found 4 things that can cause the gas tank to build pressure so when you remove the gas cap you get a lot of air released. There is the solenoid on the intake, the check valve between the cannister and the tank and the cannister itself. There is also a vent valve that is in a remote spot. Does anyone know where this is located and what it looks like? Also, if you had this problem what part turned out to be the problem for you or what part(s) usually gets plugged or breaks? I guess the lines can get the charcoal in them and plug them up also.
Old Nov 28, 2007 | 03:09 PM
http://shbox.com/1/fuel_pump_wiring.jpg
Old Nov 28, 2007 | 08:58 PM
mrmint69's Avatar
Once again my question answered better than i thought it could be. I checked your site and missed it i guessed. I better pay more attention or look a little better.
ad356
Apr 16, 2015 05:38 PM
Magenta_Hearts
Mar 22, 2015 03:36 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
Deadbolt24
Jan 19, 2015 01:29 PM
blac94Z
Nov 24, 2014 07:12 PM
