Where to mount B&M trans cooler?
Old Jun 15, 2008 | 11:39 PM
93camaroLT1's Avatar
I had some retards work on my car before and they just had the B&M trans. cooler zip-tied to the A/C condenser. I just took the A/C out. How should I mount the cooler? My buddy and I were originally thinking of just zip-tying it to the radiator. Is the radiator too hot (will it melt the zip-ties or will it cause the trans. to run hotter?) What is the typically operating temp. of a 4L60 transmission?
Old Jun 15, 2008 | 11:58 PM
ttop1986's Avatar
Most people put them in front of the radiator. that's where mine is.
Old Jun 16, 2008 | 02:20 AM
Are you using zip-ties to mount the trans cooler or will they melt at this high of a temp.?
Old Jun 16, 2008 | 05:09 AM
Please limit posts in LT1/LT4 Engine Tech to ...... "engines".
Moving.
Old Jun 16, 2008 | 10:03 AM
Rice Killer87's Avatar
Zip ties would probably work,but I would use something that ghetto on my own car...
You need to use this:
http://store.summitracing.com/partde...5&autoview=sku
Its only $11 and makes it look factory.
Old Jun 16, 2008 | 01:36 PM
tording99Z28's Avatar
You could mount it "dope" style which actually mounts it to the plastic air damn under the car. I have never seen it mentioned here on camaroz28 but go to ls1tech and search for dope style and you will find pictures of it. Its pretty sick actually.
Old Jun 16, 2008 | 04:31 PM
These were on the car with original cooler. Their basically just weird zip ties, I can't believe B&M has the audacity to call these a "mounting kit" and charge $11 for it. Outrageous.
Old Jun 16, 2008 | 05:53 PM
jaguar5822's Avatar
you're partially wrong, the reason they mount it with those is so that there's not as much pressure on the rad fins. No matter what, when you are driving, there going to be pressure on the fins sideways, from the cooler bouncing around a bit. If you use zip ties, there will be a lot more pressure sideways based on the way they mount. I believe that you are also supposed to put spacers in between the rad and the cooler, not sure why.
Old Jun 16, 2008 | 10:10 PM
I'll worry about all that when my car is actually drivable.. If they atleast sold these things in a decent size pack (instead of just 4) the $20 ($11 plus ~$9 shipping at summit) would be reasonable. But $20 every time I need to pull this thing off the radiator for some stupid reason is pretty ridiculous.
Old Jun 16, 2008 | 10:42 PM
jaguar5822's Avatar
I'm definitely not arguing the cost point lol. I think you might be able to get away with zip ties if you used enough of them to spread out the pressure.
Old Jun 18, 2008 | 06:11 PM
19z28camaro02's Avatar
You can actually go to AutoZone, yea yea laugh now, right near where they have zip ties, they have stainless steel "zip" ties, except I think they crimp instead of zip.
james007moore
Jan 1, 2016 01:14 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Jun 6, 2015 08:27 AM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
