when i accelerate my "transmission" seems to rise?
Old Jan 30, 2006 | 10:31 PM
Donohue96M6Z28's Avatar
when i accelerate i can see the shifter go up.. and if i change gears and get on it. it seems really rough and sounds like the transmission is rising up and hitting? is that a bad transmission mount or something else?
Old Jan 30, 2006 | 10:33 PM
RedHottG2's Avatar
Re: when i accelerate my "transmission" seems to rise?
Yes it's the mount.
8cylinders>4's Avatar
shifter movement is normal when you get on it but if its moving more than normal and actually seems like it is hitting something your tranny mount is definitely toast
Old Jan 30, 2006 | 11:11 PM
Bayer-Z28's Avatar
Stiffer tranny mount'll take care of it. Otherwise normal....
When you accelerate the rear has a tndance to twist upward. Since the Torque Arm is connected to the trans... That and the twisting force ot the engine connected to the trans...
Old Jan 30, 2006 | 11:36 PM
i dont know much about trans mounts.. are there more than one? how much am i looking to pay for one and how bad is the labor onit?
thanks for the help guys
Old Jan 31, 2006 | 12:08 AM
T56LS102's Avatar
its about $7 at auto zone or $25 for the Energy Suspenstion one which is poly uath. and takes about 20 min to change. Only one located under the trans.
Old Jan 31, 2006 | 03:07 AM
Bayer-Z28's Avatar
I bought the Energy Suspension one. Pretty cheap. Stiffened it up quite a bit. You'll will have to slightly raise the tailshaft of the trans w/ a screw-jack to get the new one in there. (and to get the old one out) You could do it by hand I suppose if you're on ramps in your dw.Good old brute force. But it'd prolly be a major PITA.
Old Jan 31, 2006 | 07:55 AM
thanks guys for the help. i will probably try to do it on my next day off. its been annoying the shiiiiit out of me.
thanks again
Old Jan 31, 2006 | 11:15 PM
sir dyno's Avatar
installuniversity.com has a write up on repalcing the trans mount. http://installuniversity.com/install...sity/index.htm
Old Jan 31, 2006 | 11:32 PM
Z95m6's Avatar
I suggest the energy suspension ones. My local small town autozone had one on the shelf.
Old Feb 1, 2006 | 06:48 PM
i got a cheap 6.99 one.. they had a better one for like 25, but they didnt know if it was going to fit.. i put it on and it feels aLOT better.
Thanks for the help guys
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
greenzee28
Sep 25, 2015 04:29 PM
tdigger9899
Sep 7, 2015 10:56 AM
CARiD
Sep 7, 2015 08:21 AM
