when i accelerate my "transmission" seems to rise?
when i accelerate i can see the shifter go up.. and if i change gears and get on it. it seems really rough and sounds like the transmission is rising up and hitting? is that a bad transmission mount or something else?
Re: when i accelerate my "transmission" seems to rise?
shifter movement is normal when you get on it but if its moving more than normal and actually seems like it is hitting something your tranny mount is definitely toast
Stiffer tranny mount'll take care of it. Otherwise normal....
When you accelerate the rear has a tndance to twist upward. Since the Torque Arm is connected to the trans... That and the twisting force ot the engine connected to the trans...
i dont know much about trans mounts.. are there more than one? how much am i looking to pay for one and how bad is the labor onit?
thanks for the help guys
Originally Posted by T56LS102
its about $7 at auto zone or $25 for the Energy Suspenstion one which is poly uath. and takes about 20 min to change. Only one located under the trans.
thanks guys for the help. i will probably try to do it on my next day off. its been annoying the shiiiiit out of me.
thanks again
thanks again
installuniversity.com has a write up on repalcing the trans mount. http://installuniversity.com/install...sity/index.htm
i got a cheap 6.99 one.. they had a better one for like 25, but they didnt know if it was going to fit.. i put it on and it feels aLOT better.
Thanks for the help guys
tdigger9899
Sep 7, 2015 10:56 AM
CARiD
Sep 7, 2015 08:21 AM
