What's a normal amp draw from your battery?
Old Aug 26, 2007 | 02:29 PM
nb 96 z's Avatar
Question What's a normal amp draw from your battery?
Well, I'm trying to figure out why my battery is dead. I went and got it tested and .5 amps is being drawn from the battery. Is that normal, or is it just because I havn't driven my car a lot? I've only put 400 miles on it since April.
I went on vacation for about 10 days, came back and wouldn't start. So I jumped it, and it was fine. Now I havn't driven it for about 4 days because nasty weather and same thing, battery is drained.
Just trying to figure out if that draw is normal, or if I need to start looking for a short and pulling fuses or just drive it more. Thanks.
Old Aug 26, 2007 | 02:38 PM
Dave '97 Z28 M6's Avatar
If everything is off, there shouldn't be any more than 20mA (0.02 amps) or so needed to keep power to the volitile memory in the PCM and stereo system presets/clock, etc.
You're right in thinking you'll have to start pulling fuses to find the current drain.
Bear in mind when you're diagnosing this that some circuits will use power for a few seconds when first connected, then shut down.
Old Aug 26, 2007 | 03:02 PM
nb 96 z's Avatar
Shoot. Is there a common place to start looking and do I check fuses in both the engine bay and inside the car? I know I'll be checking my electric water pump wires and exhaust cutout wires. Thanks.
Old Aug 26, 2007 | 03:33 PM
n2ceptor's Avatar
Do you have aftermarket radio/amps/etc??????? Also check the map lights on the mirror... I accidently left it on before and it drawn down the battery...
Old Aug 26, 2007 | 04:08 PM
nb 96 z's Avatar
No aftermarket radio or amps. Yeah I've done that before too and I made sure they were all off.
Apr 27, 2015 06:08 AM
nosliw
Apr 26, 2015 02:13 PM
robcarnut
Mar 20, 2015 03:40 PM
silvermansteve
Mar 4, 2015 05:02 PM
97z28k&N
Jan 9, 2015 04:58 AM
