What are you guys doing when the heater hoses go bad?
Old 08-23-2010, 09:22 PM
brian12's Avatar
One of mine has gone bad and I see its in a pressed fitting. I bought some hose to rig it but the more I think about it I should probably replace all of it. I see you can buy the whole assembly but I don't have 150 bucks to blast right now.
brian12 is offline
Old 08-23-2010, 09:45 PM
You can carefully cut off the swaged collar and attach a normal hose with clamps. GM even sells the rubber sections separately to do this.
shoebox is offline
Old 08-23-2010, 09:55 PM
brian12's Avatar
Thanks for the help shoe.
brian12 is offline
Old 08-24-2010, 12:12 PM
Critter's Avatar
https://www.camaroz28.com/forums/sho...d.php?t=768521
here's the thread from where i fixed mine over the weekend. I cut off the collar with a dremal and bought a 5/8 hose from autozone that had a 90 on it like i needed. I think it was off a dodge van or something. If you need the 90 highlighted in that thread let me know and i can get you the part number that i used so you can cut it down to fit. It cost 10 bucks.
Critter is offline
Old 08-24-2010, 04:21 PM
brian12's Avatar
I did the same. Part number for the hose with the 90 degree bend is 80400CS at advance auto. I used this to replace the piece from the T-fitting to the water pump.
brian12 is offline
Jlo
02-03-2015 09:41 PM
crazypurgatory
01-12-2015 10:45 PM
pologreen97z
12-02-2014 10:42 AM
07-04-2005 05:00 PM
Red97LT1
08-07-2002 05:45 PM
Quick Reply: What are you guys doing when the heater hoses go bad?
