What would cause this?
Old Aug 16, 2013 | 03:32 PM
Stephen68's Avatar
hello...can anyone give me an idea as to what would cause my speedometer needle to shoot over to 150 mph and stick? the tach is reading fine as well as all my other gages..i was driving down the road and it just shot over to 150 mph and is now stuck....
Old Aug 17, 2013 | 07:31 PM
Stephen68's Avatar
Re: What would cause this?
Figured it out....Lose ground lol.....
Old Aug 17, 2013 | 09:52 PM
Forums are designed to help people even when they search and before asking a question. So if you would provide what ground it was, it might help someone else in the future.
Old Aug 17, 2013 | 10:57 PM
Stephen68's Avatar
The ground that was lose was the one that is in the plugin. Turns out that somehow when i unplugged and then plugged it back in after changing some bulbs in the back of the cluster that i must had accidentally pulled the ground wire/pin out just enough to make it lose. Only way i found it was by using a meter on it or i would still be looking lol....Thanks shoebox for reminding me to post the fix....i was just so excited that i forgot....
Old Aug 18, 2013 | 10:58 AM
What "plugin" are you talking about? Do you mean the harness connector for the vehicle speed sensor (VSS)? Or do you mean the electrical connector for the instrument panel board?
Old Aug 18, 2013 | 10:19 PM
Stephen68's Avatar
