What kills our window motors?
Old Apr 23, 2005 | 10:35 PM
pHEnomIC's Avatar
I hear a lot of stuff about our window motors dieing. I've noticed mine have slowed down lately but no where near as slow as one I tried at a dealership.
Is it heat, moisture, or lack of lubrication? I have my doors apart so i thought I'd do some maintainance on them if they need it.
Old Apr 23, 2005 | 11:16 PM
Joe Bellman's Avatar
Re: What kills our window motors?
Lack of lube can cause it but mostly it just a poor design.
Old Apr 24, 2005 | 07:27 AM
Kataklysm's Avatar
They are just bad is all, not that big a deal, you can get new ones on ebay for $20 and it takes less then an hour to do.
Old Apr 24, 2005 | 10:53 AM
Z28WannaB's Avatar
I put both motors on at the same time, forgot to lube the drivers side. The passanger side works perfect, however the drivers side is dieing fast.
- Z28WannaB
Old Apr 24, 2005 | 11:00 AM
pHEnomIC's Avatar
How are you supposed to lube them? I covered as much of the moving parts as i could with wd40, should that be sufficient?
Old Apr 24, 2005 | 11:02 AM
ROADRAGE's Avatar
WD40 wont help. white lithium grease is what you need.
Old Apr 24, 2005 | 04:26 PM
Digital Designs's Avatar
Condinsation can kill the motors if you live in a humid part of the country.....i opened my drivers motor and found about a cup of water came out.
Old Apr 24, 2005 | 05:36 PM
JoeliusZ28's Avatar
mainly bad design. ive also heard they suffer from being under powered. i think they switched to a cheaper vendor right around the debut of the 4th gen. the original window motors in my 92 fullsize truck still work awesome, and that thing has 192k miles on it. There are permanent marks in the window from going up and down so many times and yet it still works great.
Old Apr 25, 2005 | 09:29 AM
TimboTA's Avatar
Get in there with some white lithium, as stated. Also, make sure the thing isn't about to fall out...those rivets don't really stand up over time. There's nothing like coming to a hard stop and hearing a loud *crash* *bang* *clunk* inside of your door!
Old Apr 25, 2005 | 02:28 PM
Z95m6's Avatar
Use white lithium grease. I've read on here that the windows are just under powered. Someone wired up some relays and said that helped them a lot. Also there was a post about taking the motors apart and doing some sort of internal wiring mod to them that makes them run better/last longer. It was a long time ago. A search might bring it up.
Old Apr 25, 2005 | 03:09 PM
Z95m6's Avatar
Originally Posted by robvas
Where's a good place to buy them while we're on the topic?
I suggest autozone. They have a lifetime warrenty on them and are only $50. I just got a new one from them this last weekend. I still had the receipt from the last time i bought one from them in 01. They gave me a new one no questions asked.
Old Apr 25, 2005 | 03:16 PM
Z95m6's Avatar
http://web.camaross.com/forums/showthread.php?t=145075
Here is a good post about modifying a motor, supposedly you get more speed out of them.
Keenan
Jan 19, 2023 12:24 PM
warmeck
Feb 2, 2015 12:44 AM
capebuf
Jan 13, 2015 07:22 PM
Jazsun
Dec 29, 2014 12:14 PM
