what guage wire for dual battery
96M6LT1 is right on the money. I have dual batteries in the trunk of my 69/Z w/ welding cable. The welding cable works best because its fine strand and easy to bend & route under the car. Another good idea is to install welding cable quick disconnects ~ makes it real easy to get the batteries in & out.
if you use thin guage wire/cable you can cause a fire from the cables getting overheated
look at the battery relocation kits and look at the guage cable they use..keep it safe bro!
http://www.jegs.com/webapp/wcs/store...54692_-1_10367
There is no such thing as "a bit much" when it comes to current draw from your battery. In addition, you're going to be adding 10-12 feet of length to the cable as well. The cable size means everything when re-locating the battery to the rear. Save yourself a headache and use the 0-2 cable.
eanhl2004
Apr 4, 2015 12:01 PM
Jul 4, 2005 05:00 PM
