What else can cause starting issues?
Old Dec 15, 2010 | 07:25 PM
Lower's Avatar
I'm having intermittent starting issues with my 94 formula.
Battery and alternator have tested fine multiple times, but every few days I go to start the car and get a rapid clicking but no starting.
Connections are all tight.
It push starts fine, and when jumped by another car, all it takes is a one second touch of the jumper cables to start up.
Could it be something with a flaky RAP module?
Ignition switch?
Where should I start looking next?
Old Dec 15, 2010 | 10:43 PM
Slowmaro Z28's Avatar
Re: What else can cause starting issues?
theres many possibilities, it can go all the way from your ignition switch to the tips of your plugs, could it be a faulty distributer? eh i dont think it would be that because the car its self wouldnt run, it could be your starter, if your hearing a clicking sound its trying to engage, id try that
Old Dec 15, 2010 | 10:44 PM
or a solenoid, one of the two
Old Dec 16, 2010 | 02:16 AM
Lower's Avatar
Well what leads me to think it may have something to do with the RAP, is the other day I pulled in to park, turn off the car and sat there for a few minutes. My radio started turning off and on, so I tryed starting the car again.
I got the clicking sound but no start.
It wasn't enough time for my battery to drain, and the fact that the radio freaked out made me think the RAP might somehow be causing the issue.
Old Jan 2, 2011 | 01:16 AM
Fatdog2's Avatar
Bad starter or bad cables.Myo2.
Old Jan 2, 2011 | 10:09 AM
Chevyssoccer's Avatar
If it was RAP, I would think it would just turn the radio off, not off and on... It sounds more like the ignition switch or the connection at power distribution on the fender.
Old Jan 7, 2011 | 01:26 AM
Fatdog2's Avatar
Battery cables? Wire running to the starter?
Old Jan 16, 2011 | 11:51 AM
bill2129's Avatar
is it could where you live? cold start injecter! i had to get a new one. after the car would sit over night and id try to start it. it sounded like it was thrown up lol
Old Jan 16, 2011 | 12:21 PM
There is no cold start injector on a 94 LT1. The PCM richens the cold strart A/F ratio based on the coolant temp sensor reading.
Old Jan 17, 2011 | 12:37 PM
Z28Lightning17's Avatar
it could be the fuel pump, check the fuel pressure
Scottyboy
Feb 11, 2015 10:28 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Alex Barnes
Jan 24, 2015 10:21 PM
David Dorris
Jan 17, 2015 08:10 PM
