what does this switch do
Old May 5, 2008 | 12:37 AM
cotton42090's Avatar
I looked through the manual, and I tried searching but i couldnt find anything. It doesnt seem to do anything that i can notice..
and also there's a red light on the center console that i think might be for the ebrake, but i havent wanted to try the brake out and have it stick on, so just wondering about that too.
Old May 5, 2008 | 01:07 AM
Red93Camaro's Avatar
Maybe its a manual Fan switch? somebody definetly put that there. OR It locks the front breaks for you so you can do better burn outs? Maybe even an exhaust cut out switch?
Old May 5, 2008 | 06:28 AM
CheshireCat's Avatar
I can't tell from the picture, Is it a momentary switch or a normal switch?
If you have a 94Z with an auto transmission and it is a momentary switch, then it may be the performance shift button.
Old May 5, 2008 | 06:45 AM
That's not stock. It could be for anything.
Old May 5, 2008 | 11:41 AM
pcgamer4life's Avatar
^ +1
Reach around behind and pop that plate out (or pull the console if your hands are too big) and follow the wires. Maybe it's a switch for batmobile mode...
Old May 5, 2008 | 12:47 PM
haha it might be a batmobile switch...
It's kind of got three positions, what i would call "off", "arm", "on". its just a regular switch between off and arm, but then its momentary between arm and on. if that makes any sense.
the previous owner tells me this "The switch, I think, is a circuit breaker for the power outlet." So i'm gonna go pop the panel out and take a look at the wires and i'm going to plug something in to see if thats true.
Old May 5, 2008 | 01:36 PM
it doesnt effect the lighter operation whatsoever, so thats out.
the wiring goes right into the stock harness which makes it really look factory, or someone did a very nice wiring job.
Old May 5, 2008 | 01:47 PM
ss.slp.ls1's Avatar
That's the flux capacitor switch.
Old May 5, 2008 | 01:57 PM
You may have to follow the wiring to see what the switch controls.
Does the switch have any effect on the red indicator light you mentioned earlier?
Could be...
http://shbox.com/1/fan_sw_diagram1.jpg
Less likely
http://www.bfranker.badz28.com/fbody/hatch.htm
I can't find a working link to the performance shift button, but if you have the motor running and hit the momentary switch and the red light turns on, then it may be set up as the performance shift button.
Old May 5, 2008 | 01:59 PM
Follow the wires back and see where they lead. They did do a nice wiring job, though.
Old May 5, 2008 | 02:48 PM
i also just found that it has a clifford alarm system, but i have no manual and the remote is dead. the previous owner said he didnt ever use it.
After some searching i found several models it could be because the remote looks like the top one on this page link
its just hard to follow the wiring because it really looks factory. maybe a closer inspection will yield results.
Old May 6, 2008 | 09:13 PM
maybe2fast's Avatar
key on, switch in any position...do fans turn on?
Ericksd
Jan 20, 2016 06:07 PM
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
