What Could Damage O2s?
Old Sep 2, 2005 | 01:37 PM
WestCoast96Z28's Avatar
I seem to have a bad front O2 sensor...slow to heatup and slow switching. My question is what are the possible ways that an O2 could be damaged? The reason I ask is that this O2 is relatively new...yeah, small chance I got a "bad" new one from GM...doubt it though.
But what could damaged O2s? I heard the ceramic coating from new headers could damage them. What about WD40 if used to remove them from the manifolds? Anything else?
Old Sep 2, 2005 | 01:38 PM
teke184's Avatar
Re: What Could Damage O2s?
bad fuel?
additives?
Old Sep 2, 2005 | 07:48 PM
FNDRB58's Avatar
Running rich, especially if you have an exhaust leak...if I am not mistaken.
Old Sep 2, 2005 | 10:12 PM
Lead from leaded fuel, silicone from RTV and non Dex-Cool coolant, applying anti-sieze to the threads (sensor comes with correct amount of electrically conductive anti-sieze already applied), anything that seeps into the "air" passage on the outside of the housing - WD40 would certainly qualify. The sensor works by exposing the inside surface of a zirconium thimble to the exhaust, and the outside surface of the thimble to "air" as a reference..... and the air needs to get through the same hole on the end of the sensor as the wires.
68camaroboltz
Oct 5, 2015 01:46 PM
DelSoto
Sep 19, 2015 05:31 AM
blaze309
Sep 8, 2015 05:27 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
