What could be the cause of a dead window motor?
Old Apr 12, 2009 | 03:44 PM
DrewSG's Avatar
I changed the motor, driver side window is still not working. Passenger side works as it usually does.
It just randomly died on me. It was working fine as I can remember before it stopped working. The window is stuck in the up position.
Old Apr 12, 2009 | 10:06 PM
Switch, wiring, motor itself (usually the case).
Old Apr 13, 2009 | 12:42 AM
madhatter's Avatar
The wiring connector on mine is finicky. reach in and move it while using the switch. If it moves at all you found your culprit. I have done probably 50 different cars and a few of them had this problem.
Old Apr 14, 2009 | 07:15 PM
DrewSG's Avatar
Anything else? I've tried what the poster above mentioned with no luck. What else could make a driver side window motor fail?
Old Apr 14, 2009 | 09:09 PM
moparman's Avatar
It's time to replace the motor.
Old Apr 14, 2009 | 10:40 PM
Poor window adjustment, excess friction, broken regulator parts, use.
Old Apr 15, 2009 | 08:22 AM
twozs's Avatar
window regulator went bad on my 01 z28 NOT the motor
Old Apr 15, 2009 | 08:27 AM
twozs's Avatar
heres the invoice with the part # on it. yea i know it says motor/regulator but that was for the warranty . the code for the repair was the same. if you reference the # it comes up as a regulator Name:  recipt001.jpg
Old Apr 15, 2009 | 08:54 AM
DrewSG's Avatar
Where is the regulator?
Old Apr 15, 2009 | 09:53 AM
twozs's Avatar
its the mechanism the motor hooks up to that operates the window here a link with the picture of the part http://www.rockauto.com/catalog/raframecatalog.php go to your car and its under "body and interior" catagory
Old Apr 15, 2009 | 04:37 PM
DrewSG's Avatar
OK. So I guess it's either the regulator or the switch.
So I think if it was the regulator, I wouldn't be able to to push or pull the window down by hand with the motor out?
Keenan
Jan 19, 2023 12:24 PM
warmeck
Feb 2, 2015 12:44 AM
capebuf
Jan 13, 2015 07:22 PM
Jazsun
Dec 29, 2014 12:14 PM
