What is this??
Old Aug 20, 2019 | 05:20 PM
Sidewyz28's Avatar
What is this??
Looks like an evap line of some sort...goes back up past the fuel filter
anyways come to find out the foam hose or whatever it is was dry rotted where can I get a new one ? Not even sure what it is any input is appreciated!
Old Aug 20, 2019 | 09:59 PM
Re: What is this??
That is the EVAP (charcoal canister) purge line. Engine vacuum, from a port on the side of the throttle body, pulls fuel vapor out of the canister (in the driver side rear fender, by the gas tank fill pipe), through that line, through the EVAP purge solenoid, when the PCM commands the solenoid open.
All you need is a short piece of fuel resistant rubber vacuum hose that will fit snugly over the nylon hose and the metal pipe. It just looks like “foam” because it is so badly rotted.
With that connector missing, you have a vacuum leak when the PCM operates the EVAP purge solenoid.
http://shbox.com/1/evap_sol.jpg
Old Aug 20, 2019 | 10:20 PM
Sidewyz28's Avatar
Re: What is this??
Thanks for the reply, I went to the autoparts store before reading this and picked up a small fuel line hose that fit perfectly but after reading your post I took a look at the hose I installed and it says not for fuel injected cars?? Will I be ok seeing as theres hardly any pressure going through since it’s just an evap line? Or should I try to find a different hose
Old Aug 20, 2019 | 11:25 PM
Re: What is this??
There's no pressure at all in that line, just occasional vacuum. Good that it’s rated for fuel, and hopefully it’s stiff enough that it won’t collapse under vacuum. Should be OK.
Old Aug 21, 2019 | 03:12 AM
Sidewyz28's Avatar
Re: What is this??
Thanks again Injuneer always helpful
Old Aug 21, 2019 | 06:09 PM
94Z28LS1toLT1's Avatar
Re: What is this??
I just replaced the same exact one as yours,and Fred just mentioned a fuel hose as well,I found an extra fuel hose in my garage.😂😂
94Z28LS1toLT1
May 17, 2016 08:49 PM
1badasZ
Feb 1, 2013 12:00 AM
Mystic_350
Feb 24, 2012 11:19 PM
socal96Z28
Feb 24, 2009 03:00 PM
scottso
Jul 24, 2007 10:21 PM
