weird problem
Old Aug 17, 2007 | 06:07 PM
Nitemare's Avatar
weird problem
on my 86 camaro. fuse keeps blowing. the fuse controls the brake lights, hazards, and the little noise when you leave the key in the ignition and open the door. i kept on replaceing fuses, but i blew them when i put on the brakelights opened my door with the key in, or turned on my hazards. so i cleaned the peanut butter off the brake light bulbs, and that fixed the problem for a couple months. fuse blew again. what do i look for to fix this? i need brake lights, this is my daily driver. maybe i could disconnect the little noise when you leave the key in, how do i do that?
Old Aug 21, 2007 | 07:51 PM
95lt1a4's Avatar
Have you checked to be sure you aren't getting moisture in the tail light lenses?By the way that "peanut butter" is di-electric grease.Cuts down on corrosion.
Old Aug 21, 2007 | 08:13 PM
Nitemare's Avatar
i found a shorted out wire in the trunk, fixed.
Old Aug 21, 2007 | 09:26 PM
Mr. Wolf's Avatar
that would do it, or a bad ground as i was gonna mention
Old Aug 21, 2007 | 10:34 PM
95lt1a4's Avatar
Glad to hear you found the problem.
timmy39120
May 8, 2015 11:41 AM
Dylan Latshaw
Mar 21, 2015 09:48 AM
Magenta_Hearts
Mar 5, 2015 07:01 AM
InfernalVortex
Jan 17, 2015 09:35 AM
97z28k&N
Jan 9, 2015 04:58 AM
