voltage is low at idle. Ran computer scan
Old May 13, 2007 | 04:18 PM
mrmint69's Avatar
I ran a freescan on my computer and my voltage is 11.9 at idle. I know it is low but besides the alternator is there any thing else it could be?
Old May 13, 2007 | 04:34 PM
2000GTP's Avatar
I could just be a faulty battery not allowing it to hold a full charge. You may also have dirty/corroded connections on the charging wire running from the back of the alternator to the battery.
Old May 13, 2007 | 05:17 PM
2001NBMZ28's Avatar
If you want to eliminate the battery get it load tested free at some place like auto zone, etc.
Old May 13, 2007 | 07:55 PM
mrmint69's Avatar
The battery is almost new and was recently tested and is fine. If i had to guess i would think the computer reads the voltage on the alternator and not the battery. I will take it to Schucks since they can test it right in the car while its running. Don't get much easier than that. I will check the cables for damage or corrosion.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
jd13
Jul 30, 2002 10:35 AM
