Jacking points?
Old May 13, 2007 | 05:21 PM
JakeRobb's Avatar
Super Moderator
Question Jacking points?
I need to lift up the back of my car and get underneath. I'm using a floor jack and jack stands, not the factory jack. What points should I use to jack it up? The car is low enough that I can't really tell what's part of the rear subframe and what isn't, so any pointers would be appreciated.
Total noob question, I know. I've never had to jack up the back of this car before!
Old May 13, 2007 | 06:46 PM
2000GTP's Avatar
If I need to do backend work, I will jack up the car with a floorjack using the "pumpkin" on the rearend as the lift point. I then place the jack stands under the frame rails.
Old May 13, 2007 | 09:01 PM
Dave '97 Z28 M6's Avatar
Check out here:
http://www.installuniversity.com/ins...ift_points.htm
Old May 13, 2007 | 09:36 PM
JakeRobb's Avatar
Super Moderator
Originally Posted by Dave '97 Z28 M6
Thanks!
93 RedBird
Nov 15, 2015 08:24 AM
68camaroboltz
Oct 5, 2015 01:46 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
alliance12364
Sep 17, 2015 08:43 AM
