voltage gauge shows less then 13 volts
Old Jun 2, 2008 | 06:23 PM
ottociine's Avatar
please I need help.
sudenly I noticed the warning gauge light, after that i noticed the voltmeter showing only 12v.
How can I fix it?
Old Jun 2, 2008 | 06:29 PM
Have your charging system checked. Sounds like the alternator is not working.
Old Jun 2, 2008 | 06:41 PM
ottociine's Avatar
is there any relay that I should check?
Old Jun 2, 2008 | 10:10 PM
Nothing outside the alternator...
Old Jun 4, 2008 | 09:32 PM
ottociine's Avatar
i changed rectifier, regulator and brushes in my alternator but still not charging
Any body has any ideea. pls help
Old Jun 4, 2008 | 10:46 PM
Did you actually do any testing first?
Old Jun 5, 2008 | 05:52 AM
CheshireCat's Avatar
Like Shoebox asked, have you actually tested anything, or are you just assuming the dash voltage gauge is correct? If you have a simple multitester, set the range to 25V DC and check your voltage at the battery both running and off.
If you think the alternator is bad, take it to any of the major auto parts stores, and they will hook it up to a test machine usually for free.
Guessing can get expensive...
99TransAmWS6
Feb 12, 2015 07:23 PM
ChrisFrez
Jan 18, 2015 08:05 AM
ChrisFrez
Jan 11, 2015 03:47 PM
97z28k&N
Jan 9, 2015 04:58 AM
ChrisFrez
Jan 4, 2015 08:43 AM
