VERY strange hvac problem.Please help asap!
Ok my car only blows on the floor vents.I have replaced the check valve under the hood and checked the vacuum lines with the pump and they are all ok.HOWEVER after about 5 minutes of driving it begins to blow normally!!What the hell could be causing this!And when it is blowing normally if i turn it off then back on it starts blowing only on the floors again.Please any help would be great...about to replace the hvac control panel since i have an extra one but would like some input before taking that trim off and probally craking the dash lol..Oh also it probally has nothing to do with it but the a/c **** is barely lit up at night
Mike
Mikekatie0425143@aol.com
Mike
Could be a sticky actuator door, or something got dropped down your defroster vent. Could also be a problem with the vacuum lines behind the HVAC controller or the controller itself.
I haven't gotten too deep into F-body HVAC but these are some things to check based on other cars I've looked at.
i would change out those dash controls. your getting vacuum to them because the doors are shifting, but they return to default when no vacuum is present, which is normal, but they should immediately return when the engine is turned on.
Nayr
Mar 3, 2023 08:34 PM
RUENUF
Mar 13, 2016 03:37 PM
Henson071
Sep 21, 2015 04:31 PM
cmsmith
Sep 14, 2015 09:25 PM
tdigger9899
Sep 7, 2015 10:56 AM
