Vats disabled. Can I use a blank key without resistor
Old Nov 7, 2011 | 08:21 PM
stephenpen's Avatar
Lost the keys for my 95 Lt1 Z. I think I had my vats disabled when they retuned my computer. Can I use a blank key without resistor to start my car. I just need to put the car away for the winter. Over the winter I should be able to find my spare keys.
Old Nov 7, 2011 | 09:25 PM
Re: Vats disabled. Can I use a blank key without resistor
If all you had done was have VATS programmed out of the PCM, then you still need the chip in the key to allow starter operation. If you also did a resistor bypass or wired around the TDR, then you don't need a key with a chip.
Old Nov 7, 2011 | 10:18 PM
stephenpen's Avatar
Thanks Shoebox
Thats not the answer I was looking for but it is what it is. Is there anyway to tell which resistor I need. I'm pretty sure I saw #8 somewhere. Does tuning software list which resistor is used under vats ?
Old Nov 7, 2011 | 10:25 PM
MikeGyver's Avatar
Originally Posted by stephenpen
Thanks Shoebox
You can tell by measuring it with an ohmmeter, http://shbox.com/1/4th_gen_tech2.html#pass_key. And no.
Old Nov 7, 2011 | 10:40 PM
stephenpen's Avatar
I dont have a key to measure. I swear while my buddy had his Tech II scanner plugged in I saw something about the vats resistor ?
Sounds like I'm going to have to go to the dealer. Last time I did this 10 years ago it cost me $229 for one key : (
Old Nov 7, 2011 | 11:18 PM
The computer knows nothing of the resistance of the key. That info is in the TDM. Your best bet would be to bypass the TDR. Info is in this link.
Old Nov 9, 2011 | 02:41 PM
Guest47904's Avatar
Guest
Use the method of grounding the yellow/black wire of the TDR to maintain transmission safety. As the other method of jumping the yellow to purple wire would allow the car to be cranked in any position of the transmission (auto) or with the clutch out.
68camaroboltz
Oct 5, 2015 11:56 PM
colts0455
Oct 4, 2015 09:47 PM
colts0455
Sep 27, 2015 01:07 PM
KYWes
Sep 26, 2015 08:49 AM
autoxr166
Sep 25, 2015 04:21 PM
