v6 to v8 swap question, are the inside car harness the same v6 or v8?
Old Nov 7, 2007 | 04:08 PM
drptop70ss's Avatar
I have a complete Lt1 T56 dropout on a K member and want to install it into a v6 car. My engine and PCM harness is complete and still on the engine, just removed from the donor at the 3 plugs behind the passenger side kick panel. Is it possible to plug in a LT1 engine/PCM harness at the 3 plugs in the kick panel to the harness in a v6 car? Any differences in the wiring harnesses under the dash and out the left side firewall between v6 and v8 or are they the same? Thanks!
Old Nov 8, 2007 | 05:24 PM
93v8clone's Avatar
what kind of car cause a lt1 bell wont bolt to a v6 if thats what youre tryin
Old Nov 8, 2007 | 05:53 PM
drptop70ss's Avatar
No, I have a complete K member with an LT1 T56 and PCM with wiring. wiring is disconnected from the original car at plugs C210 C220 and C230, I want to know if I can plug those 3 plugs into a v6 car under dash harness. Assuming the cars are the same year.
Old Nov 8, 2007 | 07:58 PM
RE AND CHERYL's Avatar
There are a few wires that are different between the V6 and V8 on the C220 series connectors under the dash.
What year is the car your putting it in and the engine your installing?
Re'
Old Nov 9, 2007 | 04:14 AM
drptop70ss's Avatar
Hi, putting a 95 LT1 M6 from a z28 into a 95 camaro that was a v6 5 speed.
Old Nov 9, 2007 | 07:19 PM
AlfredB18's Avatar
Those connectors should be the same, period. The only thing that might be different would be the fact that the v6 car wasn't equipped with something like TCS or SGS that came in a v8 version.
So, you *might* have a missing option on the v6 harness. Oh well. The car should still run.
Old Nov 9, 2007 | 07:34 PM
drptop70ss's Avatar
Thanks for the reply, that was what I was hoping. Cheaper for GM to keep things pretty much the same.
Old Nov 9, 2007 | 07:57 PM
93v8clone's Avatar
If The Years Are The Same The Plugs Are The Same The Only Diff Is The Cags Wiring But I Dont See That In The In Car Harness
Old Nov 11, 2007 | 07:01 AM
I just looked up the plugs in my Helms manual and I don't see why the car wouldn't run, but the plugs are NOT the same. There are circuts in the V6 cars that are not in the V8 cars. GM does have a specific harness for each car.
Looking at the pinouts the worst problem I can see is that the cruise might not work right.
Re'
Old Nov 11, 2007 | 10:13 AM
blown94's Avatar
theres a link to shoebox's page that has those connector pinouts for the various years. I did a 94 drivetrain into a '93 body and had to move some wires around in those connectors. I kept the 4l60e and ditched the speed density setup with the 700r4. Just look at the year harness you're going to use, and compare it to the v6 harness pinouts and make the changes to the v6 harness pins to match your eng. harness. Its not tough at all. Use a pin or needle to release the pins and move them to the correct cavities.
Old Mar 24, 2021 | 09:34 PM
96z28clone's Avatar
Re: v6 to v8 swap question, are the inside car harness the same v6 or v8?
You guys are a huge help to me right about now. Im swapping an lt1 into a 96 v6 car. Where do I find the link mentioned above to see the connector pin outs? I.d like to get as many systems as possible functioning. The wife will surely complain if things like cruise control don't work
Old Mar 25, 2021 | 03:01 AM
peterpar's Avatar
Here's a link to the Shoe Box site. I'm not familiar with the site to point you to the pinout information you're looking for. You can also download complete copies of the different model years factory service manuals here which should have the same information.
Old Mar 25, 2021 | 09:19 AM
Shoebox electrical - note item #2
4th Gen LT1 F-Body Tech Aids
Lot's of other useful info on that list. Item #1 clarifies harness connections and sensors. #54 shows the data link connector (DLC) 95 vs. 96. The references are almost all specific to the LT1. You would have to look at the 1996 factory service manual mentioned immediately above to verify the V6 vs. V8 body connector pinouts. Check the coolant fan hookups.... I don't know if the V6 used dual fans with low/high speed control like the V8. And the 95 moved the “PCM BAT” fuse from the instrument panel to the under hood box, and at some point is may have been moved back.
You may also need to address the instrument cluster, since the oil pressure gauge is different, and the V6 gets tach input from the ICM, while the V8 gets tach input from the PCM.
TanTin
Jul 26, 2014 10:36 PM
Daniel6718
Sep 26, 2008 04:36 PM
erik02
3rd Gen / L98 Engine Tech
Apr 14, 2006 08:29 AM
robsenter
V6 Tech
Jul 18, 2003 01:33 PM
