Underdrive Pulleys
Old Mar 24, 2008 | 11:40 AM
19z28camaro02's Avatar
Underdrive Pulleys
The % amount associated with the pulley is the reduction amount correct....?
Old Mar 24, 2008 | 02:43 PM
A "25%" pulley will reduce the speed of all the belt driven accessories by 25%. The diameter is also 25% smaller.
Old Mar 24, 2008 | 02:47 PM
so a 20% pulley would create more power than a 15% pulley?
Old Mar 24, 2008 | 02:54 PM
JAB's Avatar
JAB
Theoretically yes, it should free up more power.
Old Mar 24, 2008 | 04:44 PM
But you aren't talking about much in the way of gains. Since the LT1 water pump is gear driven, and not belt driven, there isn't much to be saved. The reduction in the amount of energy absorbed to accelerate the rotating mass (HP loss) will be proportional to the square of the RPM. So a 20% pulley, in theory, should produce 4X the gains of a 10% pulley. Look at the savings on this dyno test - pulley % not shown.
http://www.ws6.com/mod-2.htm
The potential loss of charging capacity at idle isn't worth it, IMHO.
Old Mar 25, 2008 | 07:02 AM
THE_RUCKUS's Avatar
Personally, I like my underdrive pulleys. There is definitely some charging issues at idle for the moment, but I'm working around that. Bang for the buck; probably not worth it.. however, I like it and I'm going to roll with it.
AviatorDave
Dec 19, 2016 06:35 PM
RUENUF
Mar 13, 2016 03:37 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Slayer
Aug 17, 2015 03:55 PM
Rde Bandit
Mar 21, 2015 10:17 PM
