turn signal problems
Old Sep 18, 2005 | 01:03 AM
95_formula's Avatar
My turn signals don't work and I checked all the fuses and changed the bulb under the dash but it still doesn't work theres no blinking arrows on the dash and no clicking sound. Any help would be appreciated. Thanks.
Old Sep 18, 2005 | 07:23 AM
slopokrodrigez's Avatar
Re: turn signal problems
Try your hazard flashers, if they work, pull and replace the turn flasher located above the DLC.
If the hazard flashers don't work either, the problem is probably the turn/hazard switch assy located in the steering column.
BTW, what bulb under the dash are talking about?
Old Sep 18, 2005 | 07:59 PM
95_formula's Avatar
The hazzards do work what is the DLC? and the bulb under the dash is the dome shaped thing with two prongs.
Old Sep 19, 2005 | 07:08 PM
The DLC is the data link connector. The connector the computer Scanner plugs into.
Old Sep 20, 2005 | 11:50 AM
95_formula's Avatar
do you have any Idea how much a turn flasher will cost.
Old Sep 20, 2005 | 03:28 PM
97formulakid's Avatar
having the same problem withmine, man it pisses me off
Old Sep 20, 2005 | 04:35 PM
Please post topics like this on "General F-Body Tech....", NOT on "LT1/LT4 Engine Tech.
Moving....................
Old Sep 20, 2005 | 04:56 PM
strtracer9803's Avatar
The flasher relay is 13 to 18 dollars at the dealership, its inexpensive.. I have a picture diagram of exactly where it is if you would like it.. AIM- Strtracer9803
stangspank
Nov 13, 2015 01:02 PM
vinnyxgunz
Aug 28, 2002 09:41 PM
formula79
26
Aug 5, 2002 12:21 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
CMJ917-95CMO
Jun 19, 2002 09:10 PM
