Turn Signal/Cruise/Wiper stick Q.
My turn signals work, my wipers work. I have to pull really sharply to get my brights to come on and the Cruise Control doesn't work. Do I need to get a new stick?
on my '93z, mine is doing similar, but cruise works hit and miss. My brights refuse to go off regardless how hard the lever is pulled now, so I had to unplug the middle position lights up front for now. Wish I could help, but having the same problem. bump
Shoebox's Site to the rescue !!!
This guy is GOOD !
check here
main page - all sorts of goodies !
Look at item # 83 in the column exploded view - that's your probable problem child, unless the dimmer rod (#77) is bent.
The switch is mo easy to fix - if it's out of adjustment, you don't even have to remove it from the column.
HTH , and Thanks (again ) , Shoebox !!!!
Britt
check here
Britt
F'n1996Z28SS
08-23-2023 11:19 PM
10-31-2016 11:09 AM
formula79
26
08-05-2002 12:21 PM
